Showing results for tags 'visibility state'.
    • visibility state ×
Found 4 results
  1. Moving Attributes in a Dynamic Block I have a dynamic block with 5 display states. In 4 of the display states I need my attributes to be in different locations. I have shown the approximate location for each display state shown in a dark red color. I do not know how to mo...
  2. Hi, I have a dwg with a bunch of the same block in it (called Cabinet). This particular block has a number of visibility states. I have assigned an attribute (called SetVisState) to the block that I can modify via ATTOUT and ATTIN. I want a LISP routine to check this attribute in each block...
  3. Hello all, I've posted on SEVERAL forums trying to get an answer to this problem, I've compiled so many different Lisp routines that I've lost count, but none have quite been able to do what i want. i've attached a dwg with two blocks in it, the scope of what I'm trying to accomplish is at the bott...
  4. Hello guys! I have a block with 6 visibility which I can change easyli with the drop-down list. It works well. But if I change the scale of the block it lose the drop-down list. In the block editor I can see the 6 different states but no drop-down list in the model space. Why? Could you...
