Showing results for tags 'viewport turn off'.
  1. Hello all, Is there a way to toggle off the VIEWBASE command viewport? When I am working in Paper Space and adding part balloons, notes, dimension, etc. the viewport created with VIEWBASE lights up whenever I hover over it to select something else. Usually I end up selecting the viewport instead my intended object laying over the top of it. Its distracting with a huge assembly. Thanks in advance with any advice. PG.
  2. HI All AutoCAD isnt being nice to me lately another hassle i have is the viewports randomly turn off ( they dont show anything) and when i turn those ones on, others turn off. I suspect its a video card issue causing some sort of degredation, however i thought i'd see what you guys think. Cheers Marcus hi all, i dont know how to change the topic to "solved" however a collegue told me to enter MAXACTVP at the command line the value was 16, i was told to set it to 64 ( i had 21 viewports ) and they all came on. cheers
