Showing results for tags 'viewport selection'.
    • viewport selection ×
Found 5 results
  1. Hello everyone, this may be a dumb question but I've been struggling with it for a while now... So I am entering various drawings in (elevation, floor plan, site plan and several details. Since all of them require different scales, I am creating a viewport for each one. They all must go in...
  2. Hi guys and gals This is a modelspace viewport problem. I have my screen (modelspace) set on 3 viewports - left. I have obviously tweaked a sysvar that has had the following effect... If I start a command (e.g. circle) in a viewport that is set to world UCS, and then switch to a VP (bef...
  3. When I right click on a viewport I no longer get the menu that includes the lock/unlock choice, or anything else. I can select the viewport but I have no control over it. Also when I select objects the layer information is not displayed. Until today I did not have this problem. I'm thinking it m...
  4. erichardson
    Viewports S.O.S.!
    Hi, I was hoping someone could offer advice on setting up viewports in order to print. I understand that a viewport layer must be created to begin with but the steps following this are not clear to me. Thank you kindly, Emily
  5. On an existing file, I suddenly cannot select a viewport by just clicking. I need to do Ctrl-A. However, I do not have this problem when I tested it on a brand new file. The relevant layers are on. I can easily create the viewport but cannot just select it. What should I check on?
