Showing results for tags 'viewport scaling'.
    • viewport scaling ×
  1. This is just a general question about annotative text, something I've noticed as we transition from 'each scale has its own text-dimension layer' to 'annotative'. I'm still a bit confused by the relationship between annotative scales in both DIMSTYLE and STYLE, and viewports, and actual plott...
  2. Hi Everyone, Situation: I created a 3d isometric view of a 1/2" pvc prototype assembly I made. In model space, I'm using block attributes to label fittings and pieces to create a parts list. Problem: In layout tab I can zoom and set up my view pretty much as I want. The view scale b...
  3. Dear AutoCAD gurus, I am having a serious problem with scaling in my current project. I am using AutoCAD 2014 Civil 3D. All of my viewports are set to 1"=40', but when I print them out, they are consistently off by 1/40th of an inch. It should be noted that I first print them into pdfs, but I...
