Showing results for tags 'viewport scale'.
    • viewport scale ×
Found 9 results
  1. Hi I'm new to the site so I'll try and be as clear as possible! I am creating a new title block for my office. In the new block I am using fields to limit the amount we have to fill it out. This has worked well with the exception of getting the viewport scale to work properly. I have visited...
  2. Hi Everyone, Situation: I created a 3d isometric view of a 1/2" pvc prototype assembly I made. In model space, I'm using block attributes to label fittings and pieces to create a parts list. Problem: In layout tab I can zoom and set up my view pretty much as I want. The view scale b...
  3. Greetings all! I recently wrote a routine that took information from the user via a dialog box and populated our titlemark block. After I got this working I wanted to add some additional functionality by having the user pick the viewport the titlemark would be associated with and by using a fie...
  4. I have been looking through a ton of threads and can only find half an answer to what I'm looking for: When I draw in mm, I have to set the scale of the viewport to 1:30 or somewhere in that range. But in reality, the object that Im drawing isn't 1/30th of the size that it prints. How do I get the s...
  5. Hi All I have just installed 2012 and have drawn a 3d model. In paperspace i have a couple of viewports , all nicely set out at 1:5 scale. then i click in another viewport and bam, all the other viewports change scale (zoom out) and orientation. is there some system variable that i have overlook...
  6. Hi, I'm working on a drawing from a client which has been produced in a program called PLSCadd and exported as a .dxf file. The problem is that when I click my viewport the scale list only shows some kind of imperial measurements 1/128" = 1'-0", 1/64" = 1'-0", 1/32" = 1'-0" etc., etc. How do...
  7. Okay, I'm new to drawing and I need help getting my text/dimensions to be legible on an 11x17 sheet. I had no problems when my company used Arch D (24x36) but in an effort to "going green" we converted to the B size paper (11x17). Has anyone found a useful chart for plotting in different scales....
  8. I just started at this company and each time I try to choose a scale for my viewport I am confronted with a daunting list of hundreds of scales to choose from. Most of them have XREFXREFXREFXREF....following them. My question is how can I reset this to the default list of scales? Or at least p...
  9. Hi all I am going through my viewports properties, changing the annotation scales that for some reason are different to the viewport scales (why you would want a different annotation scale i dont know) does anyone know how when i make a viewport, with a certain scale, i can have it that the ann...
