Showing results for tags 'viewport layout'.
    • viewport layout ×
Found 4 results
  1. Hello everybody! I have a lisp file which creates 2 new commands. If I use tne first command, all the viewports in my drawing are locked. If I use the other command, they are all unlocked again. If I use these commands, also the colors of these viewports are changing. If I lock them, they be...
  2. I'm a newbie to AutoCad, I'm currently using Autocad 2012, does anyone know how I can scale a text in viewport whose drawing was referenced in the model view. Please any help will be appreciated. fyi the referenced drawing is a survey drawing. Thanks to all in advance
  3. GUY IN THE HAT
    moving viewports
    So I have a viewport, viewing exactly what i want it to in model space but it's not where i want it in paper space. When i move the viewport entity in paper space it's changing my view in model space. How do I lock what the viewport is seeing? I've tried locking, that doesn't seem to do it. I...
  4. Hello, I have a problem and it is sort of tricky to describe it without verbosity, but here it is. I am new to Autocad and I use 2002 version. Then I would like to draw some technical drawing of a hexahedron, THEN I would like to print it from three points of view top, side, perspective, all with r...
