Showing results for tags 'view port'.
Raster Image looks out of place but isn't
hcostanzo posted a topic in AutoCAD Drawing Management & Output
Hello! I'm hoping someone knows a fix for this. I'm working on a large project, and I have 14000 feet of plan & profiles split into 500 ft sections, with a raster image as the background of all the plan views. The plan viewports are rotated 36 degrees using mvsetup. The problem is that when I...- 2 replies
- raster image
- plot
only faint image of drawing in model space/view port when plotting
dreadhead posted a topic in AutoCAD Drawing Management & Output
Hello Everyone. I really hope someone can help me. I cannot plot anything from my model space. It doesn't matter if it's in a layout and using viewports, or if I try to plot directly from model space. When plotting I get a very faint image, if anything. I know my printer is working because it wil...- 12 replies
- problem plotting
- model space
I have a drawing with a parcel. I want one of the lines to be straight across with no angle. On the older version of cadd I was able to align a view port to a line. Is there a way to do this with Civil 3D 2015? If so, how would I go about do this? Or does anyone know of a trick they use to achieve t...
Clash between the old guys and the new guys!
evadtregnab posted a topic in AutoCAD Drawing Management & Output
I use the paper space / view ports for my annotations and finalizing my drawings before printing. I design all my models in model space. The old designers do everything in model space including all annotations, borders, etc. They are complaining that my autocad files do not have the final prints wit... -
Hiding an object in a viewport on the same layer as others
Liltygar posted a topic in Mechanical & MDT
I am trying to hide a specific object that is a part of other layers. I do not want to hide other layers or have this line hidden in other view ports. Is there something that can be done? i have tried in the view port to hide object, and the object was hidden in my other view ports as well. Isol...- 5 replies
- object
- layer control
Hey Everyone I was wondering as to best method to rotate view ports? Currently I insert the view port in paper space, use rotate or align to swing the view port to the rotation I need. After which I manually rotate the text items in model space so they are horizontal for each paper space. I've...
I am running LT2014, and have already created functioning layout view ports with correctly displayed objects. However, when I draw a new view port now, it does not have anything displayed in it. I have checked to insure all layers are on, layers are not frozen in view port, the view port is checke...
Viewports in macros and command lines?
MrCrozzB posted a topic in AutoCAD Drawing Management & Output
Can I modify an existing viewport in a macro or in the command line? Using a macro, I want to modify (specifically delete) the viewport from a layout tab after chspace from model space. Does anyone know how to do this? I have LT so no LISP. qselect works but cannot be put into a mac... -
Okay, this is a new one for me. I am running the antique CAD 2004 and went to layouts to start setting up a page. When I drew in the view port, it does not show anything of the model space, zero, zip, nada. Tried "Scale to fit", a new view port with no luck. I opened another project file, it wor...
