Showing results for tags 'vba programming'.
    • vba programming ×
  1. sivapathasunderam
    Create file & Run the code
    Can anyone show me with an screencast how to create vb file & run the code Private Sub CommandButtonSmooth_Click() Dim sset As AcadSelectionSet Dim v(0) As Variant Dim lifiltertype(0) As Integer Dim plineObj As AcadLWPolyline Dim oLWP As AcadLWPolyline Dim i As Long Dim var As Variant Dim oSS() A...
  2. Hi, Is there a way to generate rectangles based of the information on table. Example: Each row of would table have length, width and name information. CAD should be able to read these values and generate corresponding rectangles on the model space. Thank you, Nixon
  3. Staheri
    VBA programming
    Hello, I am trying to generate a cube filled with thousands of spheres with different size, then I want to combine all spheres, I want to program generation of such an explained medium. is it possible ? Can I find a user guide for Inventor's VBA to generate that through the program automatically?...
