Showing results for tags 'vba autocad'.
Goodday Everyone, I have created a vba code for creating Longitudinal section (inputs from excel), also I want to make a gap between the profiles if a row was empty in excel. Can anyone guide me through this!? Thanks Regards, Vasanth. S
Hello, my problem is that when i use the function: Dim z As Double Dim h As Double Dim c4(0 To 2) As Double z = Val(TextBox2.Text) / 2 h = Val(TextBox3.Text) c3(0) = 0#: c3(1) = 0#: c3(2) = 1# radius1 = z height1 = h Set psr = ThisDrawing.ModelSpace.AddCylinder(c3, radius...
Good Day, I would like to request an accessible files of autocad vba (userform/macro/.dvb/.frm). What I am trying to achieve is a toolbar that allows me to compute values and arrange it in a table per layers. Any files could do, related or not, finished or not, i'll try to get some ideas/codes/form...
Hi guys, Long time ago ,I have written this lisp routine, This routine inputs a reference points coordinates, elevation and distance values from screen. It calculates several new points elevation and distance values and writes their elevation and distance values on screen. Can anyone help me c...
Hi, Is there a way to generate rectangles based of the information on table. Example: Each row of would table have length, width and name information. CAD should be able to read these values and generate corresponding rectangles on the model space. Thank you, Nixon
- 1 reply
- vba autocad
- programming
Hi All, I have an AutoCAD VBA program where i'm fetching records from Oracle DB which is having lakhs of records.so when i execute query it takes long time to return the recordset. I would like to show a progress bar to the user during these recordset retrieval time and for the further process....
hello in autocad block 4 line TXT TXT1 (handle # 3) TXT2 (handle # 2) TXT3 (handle No. 4) TXT4 (handle # 1) When I recuper the string in a combobox it puts me in the order of handle TXT4,2,1,3 I then I want in the order of the line screen TXT1,2,3,4 Thank you for your help ****...
