Showing results for tags 'variable name'.
    • variable name ×
  1. Is it possible using AutoLISP to define a variable name from the command line when running a function? I want to input the name when running it from the command line. Can I do this and still have the variable be global? If so, how would I go about that? Thanks in advance.
