Showing results for tags 'user input'.
    • user input ×
Found 4 results
  1. Hi guys, I'm new to this forum and new to programming with lisp - please be kind.... The code I am writing will draw a 3dPolyline from a specific point to another point (usually with a lower z coordinate), the polyline will then be converted to a spline, a circle will be drawn at th...
  2. Lee Chu Chu
    ESC User Input
    Is there anyway to check to see if the user has inputted into the command line and using a lisp, to tell that as soon as the user has pressed esc to not only cancel the command but to also set quantities?
  3. I needed to print 200+ drawings located in multiple locations, but only a section of each drawing that was not previously defined by a view or common coordinates... A batch printing process that could pause at each drawing to accept user input was what i was after. I stumbled upon a bundle of code...
  4. meyerforhire
    Interactive Insert VBA
    I'm trying to build a "smarter" insert routine for placing furniture blocks. What I mean by "smarter" is I'd like the user to be able to control, preferably by keystroke, whether to mirror the block or rotate it by a fixed angle on each depression of whatever key I decided. The problem I'm having is...
