Showing results for tags 'user defined parameter'.
Hi everybody, I defined two parameters inside "Dynamic Block" and called them "elements_hor_dist" and "elements_ver_dist". Now I want to use Array action (BACTION Array), but BACTION uses just parameters defined with BPARAMETER (i.e XY). Is it possible to put user defined parameters in de...
- dymamic block
- bactionbar
Hi all, I defined a dynamic block containing some user defined parameters. When iserting attributes, I define one of parameters as a field. But after closing the Block Editor and inserting the block, It show just the word "UserVariable" instead of real value of the parameter. Does anyon...
- user defined parameter
- dymamic block
