Showing results for tags 'user break'.
    • user break ×
  1. In this portion of a continuing program I'm putting together, a 4' block is inserted at a user point at a defined angle, then it is again inserted but this time 4' away at the same angle so that the two blocks form an 8' line. This is continued until the user stops the program. However, when the sec...
