Showing results for tags 'update fill'.
    • update fill ×
  1. I want to remove all data labels from a drawing and I want hatches to fill the gaps. All hatches are created as associative fills. When I remove data labels using a Quick Select or Select Similar command only a few neighboring hatch areas are updated. As for the remaining gaps from labels pe...
