Showing results for tags 'unknown command'.
_ColorOffsetV031 Unknown command "COLOROFFSETV031". Press F1 for help.
AM-AP posted a topic in AutoLISP, Visual LISP & DCL
Hi there, I'm AM and new to the forum I'm creating a set of easy lisp routines for my team. I've loaded the following lisp file into AutoCAD and it works fine when typing the function ColorOffsetV031 into the command line within AutoCAD. However, when I try create a new command that wil...- 10 replies
- lisp
- unknown command
I am trying to convert text to mtext but the "txt2mtxt" command is not working. all the other express tools are working; this command shows up as unknown. I have searched for this command on the apploader and had no luck. How do I get this command to work?
- 1 reply
- txt2mtxt
- startup suite
After installing 2014 last year, one of my guys compained of his software locking up and showing the message on the command line "unknown command". You could still pan and zoom, but nothing else. Even the "X' in the corner of the file or software would not exit the file or software. I thought it was...
LISP - Unknown command for lot of well known LISPs - Solved
p0peye posted a topic in AutoLISP, Visual LISP & DCL
Hi all, I am a bit frustrated as my second question is (also) on first grade (elementary school) level, but I have already spent too much time trying to figure it out: I need to go trough many old drawings and replace the font type, and to change/exclude some text from exploded drawings - (M... -
Macro - Unknown command for any multiple command
p0peye posted a topic in The CUI, Hatches, Linetypes, Scripts & Macros
Hi all, I am encountering a strange problem: Which ever "multiple" command I enter - I get aforementioned error. Example Command: ^C^C_Selectsimilar;\;change;p;c;7;; Unknown command "^C^C_SELECTSIMILAR;\;CHANGE;P;C;7;;". Press F1 for help. _Selectsimilar;\;change gives me th... -
I recently updated my autotrack software to 10.2 version. Now autrack wont work in CAD where it hass previously. i receive Unknown command "ATRALIBRARY" when i click on the autrack library button. Im aware this is may be telling me that i may have installed the update in the incorrect / diff...
