Showing results for tags 'ucs copy paste'.
    • ucs copy paste ×
  1. Hello all and thanks ahead of time for any guidance. To simply put it, I am grabbing linework from a dwg and copying it from base point 0,0,0. in the drawing that I want to copy it into, I hit ctrl+v and type 0,0,0 to put it exactly where it needs to be. For some reason, that I cannot figu...
  2. equilateral-square.dwg In layout 1 of the attached file, I did something wrong. I copied the borderline and bottom annotation from another file using ctrl+C, Ctrl+v method. After that ucs icons are doubled. I deleted the viewport and made another one by mv command, however the problem still is t...
