Showing results for tags 'trim line'.
    • trim line ×
  1. iam need lsp for trim or erase many lines inside many circle or block circle on one at one time Drawing3.dwg
  2. Hello everybody! If I want to use the "extrim" command, I do select a line first and after this I click on side next to the line. After that, AutoCad does, first, zooms in very, very slow to the line I'd selected. Second, he trims all the lines next to the selected line, on the side I've cho...
  3. Hi Guys, i have some drawings with blocks in them, (CAD file has been Attached below) Sample Block.dwg sometimes, i need to trim the lines inside the blocks. (Screenshot below) As Trim Doesn't Work on Blocks, i had to explode or burst the blocks and then trim the lines. But i don...
