Showing results for tags 'tool palettes'.
How to fill in blocks attributes in by inserting them from a palette (.xtp file)?
detomas83 posted a topic in AutoLISP, Visual LISP & DCL
Hello, I have created a palette with several predefined blocks. However, I would like to use the same block for several icons, by filling in specif attributes with different values. Eg: Palette Icon1-> BlockName: Block X, Attribute1: A Icon2-> BlockName: Block X, Attribute1: B Icon3->...-
- tool palettes
- block attribute
Hi all, I have a tool palette I've created using dynamic blocks all saved on a shared server. I have all of the blocks inserted on a source file. I copy and paste them into the tool palette and it all works great. When I open up the palette the next day, it is empty and none of the blocks are th...
Hey everyone, I'm new here, at least as a poster. I've found tons of great info here on the forum, but not one that that quite deals with my issue. I'm the newly-elected CAD Customization Committee Head and I'm trying to get my Tool Palettes to work over our network. The palettes I've created o...
- 3 replies
- network
- tool palette
Windows in tool pallets covered by solid hatch in walls when laying out floor plan
Jodi Muir posted a topic in AutoCAD 3D Modelling & Rendering
Hello everyone, I've always layout my floor plans three dimensionally with the tools pallets commands such as walls, rails, door, windows & ect. I always have my walls pre-hatched with the solid pattern which is really effective to the floor plan. Normally when I put windows in the wall the window i...-
- wall creation
- wall
I am new to using Tool Palettes. I have created a folder on my C: drive which contains all my tool palettes. Right now, I get the symbol of a circle with a line drawn through it and cannot use my tool palettes. In the Options tab, I noticed that there are the "Tool Palettes File Locations" and...
Can I use an alphanumeric character in a custom palette?
kt3 posted a topic in AutoCAD Beginners' Area
Hi everybody, After a fruitless search for the answer to my question on the forums, I realized I should ask it myself... I am trying to create a custom palette with symbols that I use in day-to-day work. Ideally, I'd like to add a tilde, rotated 90 degrees and with a specified line thicknes... -
Setting Tool Palettes File Locations and Authoring Palatte File Locations
ColinHolloway posted a topic in AutoLISP, Visual LISP & DCL
Hi All, Using LISP I can set the Tool Palettes File Locations using vla-put-ToolPalettePath but I cannot find a way (without putting the value directly into the Registry) to set the Authoring Palatte File Locations. Is there a way to do this without accessing the registry directly (using vl-reg... -
Anyway so here's the problem: I am struggling to edit the standard set of blocks that comes with AutoCAD such as receptacles junction boxes etc. I want to edit the standard blocks and then save my changes for future use. Right now the blocks come in at different sizes then I would like. I try to...
- 2 replies
- tool palettes
- error
Stairs and Railings Tool Palettes Missing in English Version
one25IT posted a topic in Architecture & ADT
I was able to create palettes manually adding AEC objects from the Design Tool Catalog through the Autodesk Content Browser. Still, the English catalog library doesn’t feature all the AEC objects seen in the German version of Autocad Architecture in Youtube tutorials. Does anybody...- 3 replies
- design tool catalog
- content browser
