Showing results for tags 'tool palette'.
loading into empty tool palette doesn't work
Cadman1957 posted a topic in The CUI, Hatches, Linetypes, Scripts & Macros
Good morning, I've created quite a number of tool palettes, including nine palette groups, and everything has been working great. Now, of a sudden, I can't drag and drop any type of entity into an new, empty palette. I can still load whatever I want into an existing one, but nothing into a ne... -
tool palette - shared
DesmetMartin posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hello all, I made a tool palette for everyone at my work. This tool palette is shared so everyone can use it. Now, there are some people who want to make an own tool palette... The problem with this is, that when they make one, everybody sees this tool palette appear. How can they make a... -
dear experts, apologize if this question was already addressed, but I fail to find a solution. Is is possible to enable/disable programmatically (AutoLisp/.NET) a Tool of a given Palette . I mean, how can I set a given tool of a palette such that it is grayed out and inactive but still displayed...
- 1 reply
- palette
- autocad 2015
block won't load into empty tool palette
Hello and happy Friday! I have made the toolpalette group i want to send across the network. I have one issue with it though. Lets say my palette is named 'Happy Friday'. When it is put in place it is now named 'TOOL PALETTES - HAPPY FRIDAY'. Does anyone know how to make it display the way it's...
i am setting up are company for 2015 and have a issue on computer A tool palettes look and act correctly i left the ootb path and added a new custom path for the location of are tool palettes. i exported company profile, copied .atc files and install all on computer B computer B will show the...
Hey everyone, I'm new here, at least as a poster. I've found tons of great info here on the forum, but not one that that quite deals with my issue. I'm the newly-elected CAD Customization Committee Head and I'm trying to get my Tool Palettes to work over our network. The palettes I've created o...
- 3 replies
- network
- tool palette
Read information from drawing and use it in a command string
Taurenis posted a topic in The CUI, Hatches, Linetypes, Scripts & Macros
Dear CAD specialists, is there a way to read information from drawing (e.g. content of a specific text object, content/value of specific attribute or any other object that I can place in a layout) and then put that information in a command string? LISP is not in the range of solutions as: 1...- 17 replies
- plotting
- page setup
Dear All, I am looking for a way to add justification to a newly created text palette. I have a mtext set to the correct layer, color and size and justification. I dragged it to the tool palette and everything works well except for the text justification. I have checked the properties on th...
- 1 reply
- text justification
- palette
I want to add a macro using a spline command...i think?
spaulus posted a topic in AutoCAD Beginners' Area
I keep doing the same commands over and over and I think i can use a macro to take some of the work out of my repetitive task. I pick "spline" and then type "near" (osnap), pick the first object then pick a spot in space then type "near" (osnap) and pick last object (end of routine). so woul... -
creating a text style? with oblique of 30 & -30 for isometrics
spaulus posted a topic in AutoCAD General
Do i need to create 2 styles, 1 with oblique of 30 and 1 with oblique of -30? Also can i put these on a tool palette? Thanks- 11 replies
- text style
- oblique angle
Redcorded Macro to shortcut key
Nobull84 posted a topic in The CUI, Hatches, Linetypes, Scripts & Macros
I'm just learning how to utilize recordable macros. I have a simple one that I found how to assign to a tool palette by simply changing the properties command string to "^C^CBottom" and "^C^CTop". These are the titles of the macros I created. The article I found explaining this said you can also ass... -
Moving from AutoCAD 2002 to AutoCAD 2014...block issues
I am going to be moving from 2002 to 2014 within the next 2 weeks and have been having trouble with my custom menu and lisp routines in 2002. I had my menu setup with custom toolbars with flyouts to select blocks to insert. Most of the blocks ran a LISP routine that did several things, the main thin...-
- tool palette
- custom blocks
Hi all, I'd like to share a program I wrote to give me quick access to AutoCAD commands and their defininitions. It's a great learning tool and excellent for when you KNOW a command exists but just can't quite find it. It's got a quick search box and also allows you to run commands by double-click...
- find
- definitions
Synchronizing tool palettes on modification
freek posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hello community! First post ever. I've been spending so much time trying to figure this one out that I kind of gave up. Now I need your help. I have 4 computers sharing tool palettes on a network. Whenever a user updates the palette with a new block, he has to export the .xtp file on the net... -
I am new to using Tool Palettes. I have created a folder on my C: drive which contains all my tool palettes. Right now, I get the symbol of a circle with a line drawn through it and cannot use my tool palettes. In the Options tab, I noticed that there are the "Tool Palettes File Locations" and...
I want to create wall types based on certain assembly types with the true rather than nominal block and brick dimensions, and add them to the wall tool palette. How do I do this? Also, the hatch for a CMU wall is a 45-degree double line. Drafting standard I am accustomed to is single line perpend...
- 3 replies
- tool palette
- hatch pattern issues
Tool Palette Layer switching with multiple operations in command string
CADSinT posted a topic in AutoCAD Bugs, Error Messages & Quirks
[Maybe this item is covered somewhere in the forum already, but to me it was impossible to find] Hello, Tool Palettes are useful to force certain drawing operations into specific colours, layers, line weights etc. Drawing in layer A, it can be used to draw a dimension in layer B without man...- 1 reply
- layers
- command string
