Showing results for tags 'titleblock attributes'.
    • titleblock attributes ×
  1. Hi! I am just new here and also a newbie in doing lisp routines. I was wondering if there is an autolisp that could possibly delete a text value of a specific attribute text inside a block of a block. I don't want to totally delete the attribute, just the value. I already tried several examples on t...
  2. Hello, I am looking for a .lsp that will allow me to insert a titleblock of a different size and run a command on the existing titleblock and click on the new titleblock and it will retain all the same information (even with text fields) and copy over the information into the new titleblock with...
  3. I have a few title blocks. one for each size of paper that I can print on. I will start working on a drawing and add another page. I will start out with lets say 5 pages and then realize that I need to add another page. at first I would go into each block and change the attribute to reflect the numb...
