Showing results for tags 'title block'.
Insert Block With Fields - Fields Not Added to Drawing
ILoveMadoka posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
I have several blocks that have fields created withing them, when I insert the block into a drawing then go to Drawing Utilities -> Drawing Properties those fields are not in the list to edit. I know how to go through the tedious steps of manually re-entering every single field b... -
Hi, Good day to you all.I'm new to this forum. I hope you people can help me out. I'm working on, automatic creation of title block with required scale setting in 'Model space' not in layout. by clicking a button or comment, it should ask the user to select the 'title blocks' among the list,...
- 14 replies
- scale block
- profile
Hello! I have a question like this before but after some answer and help i couldnt make it. I have googled for like 15 hours overall and this is my last way out What i need is to extract data of mutable drawings and change for example the description in the "title block". Not the same desc...
Over the last week or so I've been updating some more of Kenny Ramage's old tutorials at AfraLISP. There are now 116 updated tutorials. Today I just completed an AutoCAD tutorial using a (little known?) Express Tool called Rtext (Remote Text). Although I was dimly aware of this feature, I've bee...
- 12 replies
- customization
- rtext
Same title block on multiple layers
vinstermonster posted a topic in AutoCAD Drawing Management & Output
I have a title block with attributes and I want to be able to update just the first page with info (such as client name and address) and then have that data go on multiple versions of the same block on different layers/pages. I know it can be done but I've never created a title block from scratch. T... -
Attribute in title block exists in BLock Editor but not in Project.
Pawnsurfer posted a topic in AutoCAD Drawing Management & Output
Hi all, First the details: Autocad 2011, Electrical package, Fairly experienced user with some formal training. I have a problem that seems simple but has me stuck. I have an existing title block a few text attributes, to which I wish to add a watermark. I have added it in the block editor... -
title block basic setup - dwg vs dwt - etc
adnet23 posted a topic in AutoCAD Drawing Management & Output
i've learned a few different techniques for making an affective title block but i want to weigh in on what you guys think as I have not mastered this yet. Right now i'm drawing my title block linework and permanent text in model space. then I xref that file into paper space of drawing for each l...- 4 replies
- title block
- title
AutoLisp for compiling of block attributes from csv file
nicodam84 posted a topic in AutoLISP, Visual LISP & DCL
Hi i'm looking for an Autolisp that help me to compile title block starting from a csv file. At the moment I know this Lisp http://www.lee-mac.com/updatetitleblock.html It is exactly what I need. The problem is that this program compile all the block title (present in "model" sheet) with...- 23 replies
how to generate drawing list automatically by project manager (autocad for mac)
intheroom posted a topic in CAD Management
I'm using autocad2014 for mac. I've just started to use project manager for managing drawing for the project. I have some questions. 1. is there any way to generate the drawing list automatically from project manger ? like from all the layout's name ? (I use a title block with field(layout na...- 2 replies
- project manager
- field
Title Block/Field Not Working as it Should
albus1981 posted a topic in AutoCAD Drawing Management & Output
Hi I'm new to the site so I'll try and be as clear as possible! I am creating a new title block for my office. In the new block I am using fields to limit the amount we have to fill it out. This has worked well with the exception of getting the viewport scale to work properly. I have visited...- 25 replies
- title block
- fields
Does anybody know what happended? when i inserted the title block on paperspace, the lines and border were there but texts and Icon were missing, i change to difference layer when i inserted to see the difference was but still missing. Appreciate for any suggestion. Note: Layer was not turned off o...
automatic fillling out of the title block
ryan osmun posted a topic in AutoCAD Drawing Management & Output
i design pools, i am trying to find a way to have the title block for each company automatic populate from say a program like MAS. is there anyway to have CAD pull inforamtion from another program to auto populate a title block? i design for about 20 different companies a day so not having t... -
Hey guys, I'm currently editing a pre-existing Title block to suit my needs, I've made my title block and when I'm in the block editor it looks how I want it too, The only issue is when I exit the block editor and return to the normal layer all my attribute editors disappear and the original...
- 7 replies
- definition
- beginner
extract and copy attribute and move to X,Y coordinate
GISdude posted a topic in AutoLISP, Visual LISP & DCL
Hi all, I've just been given the mother of all assignments. I have abou 490 dwg files that have a title block in model space that is an old one and I've been told to take the dwg number and place it in a X,Y position in model space. As far as I know, the title blocks for all 490 files is the exac...- 3 replies
- model space
- attributes
Need help with figuring out what scale to type into my title block. I am in version 2010, doing this via correspondence, never use Paper space or Layout space (are those the same thing?), always draw at full scale, and submit my drawings in Model space. Here's the thing. In my previous drawing...
Part file location in title block?
andrewmmccallum posted a topic in AutoCAD Drawing Management & Output
Hello, I’m trying to save myself a bit of time and was wondering if it is possible to have part of the file location displayed in the title block? The current title block we are using shows the full file location of the drawing but I was wondering if it is possible to show only part of this?... -
Attaching an Xref to my title block
ktcollardson posted a topic in AutoCAD Drawing Management & Output
Hello - I am trying to attach the client details as an xref to my title block. This is how it was done at my previous company, but I did not set that up, so I don't know how it was done. The problem is this - when I attach the xref, I cannot see it on my page in paper space. If I zoom out as f...- 4 replies
- title block
- insert
Is it possible to create a drawing in wich you switch between 2 laguages. I would like to use the same drawing for our own workers here in the netherlands and a company in Poland. So I need one partslist in dutch and one in english. I don't want to make two separate drawings, because then I would...
- 3 replies
- parts list
- language
Autocad annotative scaling and title block with attributes
cnash52 posted a topic in AutoCAD General
I was just notified I am supposed to show a small class how to make our company title blocks using attributes and what annotative scaling is and how to use it. Can anyone direct me to videos or related forums so I can set up something to show tomorrow morning. We are going to be setting up our blo...- 2 replies
- blocks
- attributes
"Created By" System Variable
jwhitens posted a topic in The CUI, Hatches, Linetypes, Scripts & Macros
I've currently taken on the task of updating my organization's title blocks. I'm utilizing Fields in the title block in conjunction with system and sheet set manager variables. I've noticed in the Field Dialog Box there is a CreateDate field choice to display the date the file was created. My que...- 7 replies
- title block
- system
Hi all It has been a long time since my last post but here I am again. I have some problems with sheet templates (or is it drawing templates ) here is what I need to have: 1) drawing template with 1 sheet when new drawing is created. 2) when I add second, third and more sheets, it sh...
I'm be battling this all day and can't work it out. I've got a drawing and title block and a table with text on my model space. When i create viewports etc and try and sort out the layout, the text in the title block and key disappears. I'm probbaly doing something very basic wrong! Any ideas...
- 16 replies
Hi! I want to import default templates (Title Blocks) with in Auto cad. Is there any option ? How to proceed? Thanks in advance Atul
- 3 replies
- templates
- autocad 2011
help -title block and border not showing in preview!
dubking posted a topic in AutoCAD Beginners' Area
Hi guys, i have had to learn CAD this weekend to pass my degree, i had to create an alloy wheel front and side profile views, my problem is this - i have created the wheel in model space but when i goto layout 1 / paper space and insert my title block and border, then insert my viewpoint of...- 12 replies
- title
- print preview
