Showing results for tags 'text width factor'.
Find All Text That Does Not Have Text Width Factor = 1.0 Then Change Font
THansen posted a topic in AutoLISP, Visual LISP & DCL
I am looking for a way to find ALL text that does not have a TEXT WIDTH FACTOR (TWF) = 1.0. Then I want to evaluate the current TEXT WIDTH FACTOR setting and substitute a different font with a TWF = 1.0. Rules: 1.) If TWF is between 0.96 and 1.04 then change font to Arial Regular and set...- 9 replies
- change font
- change font selectively
Fully Searchable PDF output How To Fix. Text Width Factor, Oblique Angle, Mtext
I have been working to correct issues we did not realize we had with PDF output from AutoCAD DWG and Inventor IDW files. I have seen several posts related to the same thing so I wanted to share what I have discovered and the fix for it to date. If you are finding that your DWG files or IDW file...- 4 replies
- searchable
