Showing results for tags 'text size'.
Text size and Object Problem in Base ( from Model Space)
S43MG posted a topic in AutoCAD 3D Modelling & Rendering
So recently we got few assignments and we were given the given the video on how to like make 3D object and select it and a new page called layout is formed where all the views like top, front, side and isometric view can be displayed for the selected object. I have already set the Units... -
Hello, I am having trouble with the text size of the toolpalettes. All other items are just fine. If you have any suggestions it would be greatly appreciated. I am running 2016 and 2018, 2018 looks great, 2016 looks like the image below Regards, Phil
I have created a new multileader with the settings that the multileader type is "block" so that the end of the leader will have a detail bubble on the end, my problem I am running into is the text size inside that bubble is too small, how do i adjust the text size with keeping the bubble the origina...
- 1 reply
- leader
- detail bubble
