Showing results for tags 'text problems'.
    • text problems ×
Found 6 results
  1. We have Map 2011 and I created a drawing with several tables pasted from Excel. Also, we are currently restricting our file format to AutoCAD 2010. The tables pasted from Excel initially worked great and I was able to perform several edits and plots without any problems. That is, until another u...
  2. Hi, I am struggling to input text as part of a script. If I type it in via the command line it works. This is what I currently have. Text 7.838,1.205 0.094 0 "Text" Text 7.838,1.205 0.094 0 "Text" Text 7.838,0.936 0.094 0 "Text" If this cannot be done, I could use a b...
  3. I've read about the new option in Text Editor to be able strike through text in Multiline Text, but when I upgraded to 2013 I did not have the option. When I search the help section it explains what the strikethrough text style is but not how to add it to my Text Editor ribbon. My understanding...
  4. Hi All I was wondering if anyone has experienced this... I go into a viewport and try to change text size from say 1000mm to 600mm but when I enter the text becomes HUGE as if it is in paper space. I can get around it by scaling the text, but does anyone out there know why it happens?...
  5. Hello all! Got a text problem, and I am hoping that one of you fine users can give me a solution for it. Maybe Autodesk released an update or something that I haven’t heard about to fix this.... First off, this issue seems to be totally random, happens sporadically in different drawings. Say I h...
  6. Basically I am trying to delete some text that is in paper space but it won't let me select it to delete, edit etc. Tried regening and restarting autoCAD no success. Any suggestions? Cheers
