Showing results for tags 'text height'.
    • text height ×
Found 5 results
  1. Hi everyone, Setup; OS: Win 7 Pro X64 Product: AutoCAD 2015 Electrical CPU: i7 Graphics: AMD FirePro M6100 FireGL V Ram: 16GB Problem; I've created a datalink table to an Excel spreadsheet, and I'm only having issues with tables that required a break (table wrapping). Once I...
  2. I've working on an A1 border that matches our ANSI D border. We use the following text heights: 1/16" 3/32" --- Our standard text height for most work 1/8" 5/32" 1/4" Does anyone know what the BSI or ISO standard text heights for an A1 border would be?
  3. I usually draw in model space 1:1 and then scale my drawing in paper space to fit my sheet, but when I'm scaling I also scale my text. Is there a way to keep my text at 1/8 even after scaling my drawing from model space? thanks
  4. I am trying to dimension a 1/8" drawing (in model space) and the text height on the dimensions is so small it is not even readable. I have tried modifying the dimstyle to have an "Overall Scale" of 96 (under 'Fit') and a "Scale Factor" of 1 (under 'Primary Units') and vice versa, but neither is work...
  5. Greetings everyone; I am trying my hand at annotative text and I am about to pull out what little hair I have left in trying to figure out how exactly to set the dimension text in model space so I can see it and still be annotative. Here's the problem. I am creating a drawing 1:1 in model space like...
