Showing results for tags 'text edit'.
    • text edit ×
Found 4 results
  1. thbaiju
    Block explode
    Hi all, here Iam attaching a drawing which I need to edit the text. If I explode the block all are coming with lines and arc...do you have any solution Test.dwg
  2. I would like to add a custom command to the Text Editing Shortcut Menu but cannot find it in the CUI? I am trying to add a command right between "Update Field" and "Convert Field to Text". Can anybody help me find where to insert this command so it will show up in said shortcut menu?
  3. What I want to do is have text edit for single line text to start at the end of a string of text instead of high lighting the entire text. Is it possible to do this? Thanks
  4. I'm on Autocad 2008. I can not edit an existing MTEXT text when I double click it. Is there a commond that needs to be turned on or off? Thanks Carol
