Showing results for tags 'text display'.
    • text display ×
  1. Hello! I've run into this a couple times lately. Text or mtext will become a squiggle. This is usually in a block, maybe even within a block in an xref. Hopefully the image shows below.
  2. We use linestyles for utilities such as w for water, s for sewer etc. linestyles look like --w--w--w--w--. in Autocod 2004, if you reverse direction of line or rotate line 180 degrees drawn with this linestyle, the w's would look like m's because text reversed with line (this is what i want to happe...
