Showing results for tags 'text array'.
    • text array ×
  1. Is there any way to pull text from a spreadsheet into arc-aligned text? Like if I were trying to make round inspection tags but didn't want to type in the inspection code each time, or if I needed to change something? Is it possible to put a field into the text to refer to a cell location in Excel?...
  2. hi.. need help on creating lsp that can: > arraying text from base line until the target line with suffix number +1 image example; ````````````` thanks!
