Showing results for tags 'text aligning'.
    • text aligning ×
Found 6 results
  1. Hi everyone, Setup; OS: Win 7 Pro X64 Product: AutoCAD 2015 Electrical CPU: i7 Graphics: AMD FirePro M6100 FireGL V Ram: 16GB Problem; I've created a datalink table to an Excel spreadsheet, and I'm only having issues with tables that required a break (table wrapping). Once I...
  2. I am setting up some architectural Multileader Styles to pull into various drawings as needed from the Designcenter. I have created 7 different scales of Multileaders and set their Text "Left and Right Attachments" to "Middle of top line". When I pull the styles into a drawing, the "Left Attach...
  3. Hello guys! I have a problem with the text boxes: If I write something in a text box and set the whole text to left, after save and open again the dwg the text is set in the center. Why? after saving: after re-open the dwg: Do you have any idea why happens it? Could...
  4. Here is another download link of my lisp file I've just upgrade it. To professionals, it is a little bit too messy. But it is very useful to me for years working with AutoCAD. There are 2 commands: ALT(AlignText) and = (Match text value) "ALT" would ask you to select text, or mtext, or attribute...
  5. Is there any way to pull text from a spreadsheet into arc-aligned text? Like if I were trying to make round inspection tags but didn't want to type in the inspection code each time, or if I needed to change something? Is it possible to put a field into the text to refer to a cell location in Excel?...
  6. Hi all I am having a problem with the TORIENT command which aligns text and other stuff to a particular angle for example a line Now i am very lazy and have millions of text to align with different line i wanted to make a shortcut to this command an i created this lisp [font=Tahoma](defu...
