Hi all,
I've been using AutoCAD for about 15 years, so I'm pretty familiar w/ most of it's ins and outs. I've been looking for a little faster way of changing the current layer I've on to another way. I've customized the "mouse bottons" in the CUI to "Ctrl+Click" to intialize the "Make Object's Layer Current" command. However, I was wondering if there is a way to make it work more like Photoshop. In Photoshop, when you are using the paint bucket tool and you want to change your color to another color that is already in the picture, you press "Alt+Left Click" to select the color, and when you release the "Alt" button it goes back to the paint bucket and you just color the item you want that color. Similarly, I would like to make AutoCAD do this by using "Ctrl+Left CLick" at any point to change to the layer I'm on to a layer that I select, with out actually intiallizing a command. i could of started a line command or no command, press "Ctrl" and click on the object that I want my current layer switched to and it's done. Hope this is not too confusing. If there's a way to do it in the CUI, I'm ok with that, or even a LISP would work too. THanks for your help.
Mike
