Showing results for tags 'taper angle'.
	Hey everyone i'm new to AutoCAD i need to make an adapter plate and need a bit of help, i'm trying to make two tapered holes in the plate with specific diameters on each end and i have tried cones but i don't know how to put them in the solid rectangle plate, and i have tried extruding circles but i don't have a taper angle to input only the top and bottom diameters. can someone please help Regards Helix
	I want to use the extrude, givin it a taper angle of 60 and a height of 5, just to make sure that the extrusion will close, it was suppose to make a roof like shape. Well, it was suppose to work, it always worked before. Now it just don't want to extrude anymore, when I try a message "Unable to extrude the selected object" appears. I'm getting mad with it because it has no sense, i alread tried to create another shapes but it didn't work. If someone knows how to fix it, tell me, i need to do it. Thank you
