Showing results for tags 'table lisp'.
How to unlock table cell after removing datalink using AutoLISP.?
Ashish123 posted a topic in AutoLISP, Visual LISP & DCL
Hello, I have 5000 drawings that contains three specific tables. All these tables are linked to external Excel using data links. The main issue i have is, after the data link is removed the cell content of all three tables remain locked. Is there any way to unlock the cells...- 3 replies
- script
- table lisp
How to erase Table thru AutoLISP while running Script ??
Hello All, I am trying to remove one table from my drawings. Please take a look at the attached sample dwg. I have over 8000 drawings to modify. All drawings contains 3 tables as shown in sample drawing. I want to erase table 3. The location of the table 3 can be anywhere in with in outside... -
I want to create a auto lisp programme for following As input i want to select one line from model space in auto cad and as output i want table that display length of line and whenever i change length of line, table should automatic update new length I am using auto cad 2014
Hi, Currently I am converting old type tables (text type) to real table using lisp. In this I have facing one issue, once converted to table, every time I must align the table like text height, test alignment, row height, margin and each column size (different size). I can see many expert...
- table properties
- table lisp
