Showing results for tags 'system variables'.
I'm trying to update a few system variable in C# based on what button a user selects. I'm having some issues with the HPNAME system variable. I set the variables like this: Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("HPNAME", HPNAME); Autodesk.AutoCAD.ApplicationServi...
- 2 replies
- civil 3d 2019
- c# vs
I have been working in AutoCAD for many years and this one I have never figured out. I want 2 grips to show up with one of my blocks, how do I do that. I have a lot of blocks that I work with and a lot of them have a ton of grips that I do not want to have to deal with so I have turned grips off...
Object snap, insertion, turns itself on
WPerciful posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
I'm not sure why but my object snap turns itself on. This happens when new drawings load, between commands and when I go from drawing to drawing. It's the insertion snap that turns on. Also the grid snap turns itself off when new drawings load, between commands and when I go from drawing to dr...- 3 replies
- system variable
- object snap
Evening All I have a scenario where I want to use some thing like the system variable CTAB in a field but have it report another Layout Name in the drawing rather than the Layout that I'm working in. Let me explain..... I'm producing phasing drawings for a well known supermarket and I use t...
- 11 replies
- system variables
- ctab
I have developed a handout for my students and graduates I thought I would share here: www.KishwaukeeCollege.edu/cad Hope it helps our cause.
How do I pull up the system variables dialog box? (also is it considered a dialog box?) I've always changed individual variables at the command line and in all honesty I didn't even know there was a Dialog box for them until I saw a picture of one on a post here. Sorry if this is a silly qu...
Freezing Dimensions Problem In PDF after DWG to PDF export.
3dwannab posted a topic in AutoCAD Beginners' Area
Hi this is my first post and have been using AutoCAD since R14 but actually just noticed this. All layers in there are as exactly as they should be expect a few lines which are on 'LAYER 0' So I've exported the drawing by printing from DWG to PDF. I've tried freezing the Dimensions but I hav...- 9 replies
- system variable
- dimensioning problem
Does the VIEWRES setting affect the printed resolution or only the on-screen view? I have a logo (dwg block, not raster) that tends to print fuzzy and not clear to PDF. I am not sure if it's just the PDF resolutin settings or something else... Thanks
- 4 replies
- system variables
