Showing results for tags 'system variable'.
    • system variable ×
Found 7 results
  1. NirantarVidyarthee
    Wrong value of ExtMin
    I have received the attached drawing from one of my clients. (I have removed geometry to maintain confidentiality. But it retains the essence of problem that I have). I have to write VB/A program that extracts data from this drawing. For that I need to know the extents of the drawing. The syste...
  2. I'm not sure why but my object snap turns itself on. This happens when new drawings load, between commands and when I go from drawing to drawing. It's the insertion snap that turns on. Also the grid snap turns itself off when new drawings load, between commands and when I go from drawing to dr...
  3. Hi, I'm trying to draw a MLINE using the vertex of a Polyline and that part of the macro works ok, but when I try to change the justification and/or the scale of the MLINE changing the system variables before drawing the MLINE, it doesn't work, I always get the same justification and/or scale....
  4. Hi All I have just installed 2012 and have drawn a 3d model. In paperspace i have a couple of viewports , all nicely set out at 1:5 scale. then i click in another viewport and bam, all the other viewports change scale (zoom out) and orientation. is there some system variable that i have overlook...
  5. duckndon
    Profile Toolbar Locked?
    Running Civil 3D 2010: It seems to me that after a long session in DeepCAD, one loses the ability to use the profile toolbar. Has anyone else experienced this? It can easily be fixed by closing out of the drawing (and sometimes even the application) and then starting back up... But that just see...
  6. Hi this is my first post and have been using AutoCAD since R14 but actually just noticed this. All layers in there are as exactly as they should be expect a few lines which are on 'LAYER 0' So I've exported the drawing by printing from DWG to PDF. I've tried freezing the Dimensions but I hav...
  7. harrison-matt
    VLR-SysVar-Reactor Help
    All, I am looking for a way to create a reactor that changes a system variable back to specific variable when it is changed by a User or AutoCAD. Specifically i am talking about MLEADERSCALE, you might have noticed that if you have several styles and you switch between them your Mleaderscale...
