Showing results for tags 'switch layer'.
    • switch layer ×
  1. I'm trying to add doors where currently there are just lines for walls. Right now I'm doing that by drawing intersecting lines to use as reference points, using the trim feature to cut where I want the door, then draw the door and delete the reference lines. It's pretty time consuming, so I'm hoping...
  2. I'm using a drawing as a reference to make my own drawing, so I'm trying to switch all of the objects in the original drawing to the same layer to make it a little simpler to distinguish between the original and mine. A couple layers won't switch though. I select them all, choose the desired layer i...
