Showing results for tags 'support file'.
  1. Hello everyone; I hope you are enjoying the warmer temps, at least we here in the Vancouver Canada area are, it's only been about 7 months. Anyways my question has to do with hatches. I have downloaded a hatch file called ansi38. When I access this file from the design centre all 202 hatches load onto the right side of the design centre screen to display what is inside the file. I can drag any of these hatches onto my screen and onto an object but I cannot access the hatch editor, some error. I see that the ansi38 file is loaded into the "custom tab of the hatch type/custom hatch palette because it resides with the acad.PAT and ansi.PAT files but oddly enough only the standard ansi38 hatch is visible on the preview screen on the right of the hatch pattern palette. No matter what I do to the acad.PAT or ansi.PAT files I cannot load the desired hatches from inside the ansi38.PAT file. What am I doing wrong and why can I see the hatches inside the ansi38.PAT file from the design centre but cannot access them any other way. If anyone can help I would appreciate it.Note: All of the hatch codes inside the ansi38.PAT file are visible insode Notepad just like the acad.PAT and ansi.PAT files.I'm using AutoCAD 2010. Thanks
