Showing results for tags 'sum of text strings'.
Hello All, I am working on making Bills of Materials with Block information. I use tubing as a main component in my data extractions. What I would like to do is be able to extract the text overwritten length that I dictate from the all dimension leaders with the same part number, and add them to...
- 3 replies
- dimension
- data extraction
I have found some really great lisps that do a great job of adding a series of numbers in (dtext, mtext, mleaders, etc), but have not found a lisp that will add all if commas are being used. I would like to find something that will add all types of text numbers (dtext, mtext, mleaders, etc) with co...
Sum of numbers in text strings but in a dynamic block
dreaspring posted a topic in AutoCAD Drawing Management & Output
Dear Help, How can one add numbers in text strings that are in seperate blocks or dynamic blocks with pull down menus? I can get a sum of numbers in a text string to add up, but once it is in a block or dynamic block with pull down menus they don't all add up. How can one bcount dynamic blocks...
