Showing results for tags 'stretching dynamic block'.
Automatically updated label - Dynamic Block
Ranime posted a topic in AutoCAD Drawing Management & Output
I have a dynamic block suppose a rectangle where I applied a stretch action, I want a label telling the user the length of the rectangle every time he stretches it. A small research on the web informed me that it is possible to put a label inside the rectangle that displays its length, but when... -
I'm trying to cut down on the number of visibility states for a block under development. Currently I have a rectangle, 4'x2', with other lines that I don't need to modify. What I want to do is to stretch the rect into a 4'x4' square and add 2 circles in the corner. I have no problem with the stretch...
- 1 reply
- stretching dynamic block
- lookup function
Stretching Dynamic Blocks along an arc
stutz00 posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
I have a 4' light fixture that is a rectangle. Right now I have it set up to where I can stretch it and it copies it’s self whatever length that I stretch it in increments of 4'. Is there a way for me to modify this so that when I stretch it along an arc, that it copies its self and rotates i...
