Showing results for tags 'stretch dynamic block'.
    • stretch dynamic block ×
  1. Not sure if this is a bug but when I insert this into a drawing and then stretch it. Then insert the same file in and redefine again, it loses its distance stretched. Anyone know how this can be fixed? It's a mixture of constraints and a move action to get this Dynamic block to work. Wal...
  2. Hi This is my first post on here, I'v had much benefit over the years with queries however I cannot seem to find one that will help me this time. I'm unsure as to whether this is a glitch or an error in the block? I need a panel drawing that can be stretched both in height and vertical. Alon...
  3. Hi, I'm trying to creat a dynamic block for concrete drawing. I accomplished to make length and width variabel. But the middle bar does not stretch, it moves. Can someone help me? What i'm doing wrong? On the link below you can find the dwg file https://www.dropbox.com/s/798b595y2...
