Showing results for tags 'stretch action'.
Dynamic block - Door: Zero value linear parameter bug, stretch after flip flaw
Jooogyerek posted a topic in AutoCAD Drawing Management & Output
Hi for everyone. I made a dynamic block for doors by combining some tricks learnt from other dynamic block. By the way thanks for the shared ideas. I am almost satisfied with the result but I still have two things to figure out.: 1. If the block is rotated by a rotate action and I enter a zero...-
- rotate
- flip parameter
Addition in commandline while in command
3dwannab posted a topic in The CUI, Hatches, Linetypes, Scripts & Macros
Hi all, Is this possible. I was wanting to say stretch a wall in brick dimensions so would it be possible to type the equivalent of '225*9' (which doesn't work) while in the stretch command to give me the correct value every time. Would be a huge time saver at the moment. Even via lisp or an...- 18 replies
Dynamic Block Stretch Action Repeatedly Broken
Pline posted a topic in AutoCAD Drawing Management & Output
Hi everyone, I've learnt how to create dynamic blocks, and they're great! - within a few times of opening the drawing that is. After a while (few times of opening the dwg), the stretch action stops stretching as it should, and just moves the entire line when pulled. I then edit the dynamic block, a... -
Hello, I am trying to get two lines to rotate about two opposing circles whilst being able to stretch and also being joined together at opposite ends to the circles , so they can be controlled with one grip at the apex. I have been able to have the one set to work as i wish, but I can not get it...
- 3 replies
- grips
- dynamic stretch
What does "Radius of parameter" do?
Vagulus posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
I am attaching a rotate parameter and action to a dynamic block. I get the "Specify base point" bit okay but I can't figure out what "Specify radius of parameter" does. Do I have to include or exclude other parameters like Flip or Stretch? I get some weird results when I rotate an object w...- 22 replies
I have a dynamic block with two linear stretch actions. I can change the linear dim's through the properties but I can't select the stretch grip and drag. Tried placing the block in a new drawing, no change. Any suggestions? Section Label Block.dwg
