Showing results for tags 'stress analysis'.
Exporting Data From Labview into a Stress Analysis in AutoCAD or SolidWorks
cdorn7 posted a topic in SolidWorks
Can I import real time data that I am measuring on a real system using Labview into a stress simulation on a model of the system? Basically I have realtime force data in labview gathered from a strain gauge on a simple cantilever beam and I want to apply that force to a simulated model of that beam....- 1 reply
- solidworks
- realtime
Importing Real Time Data From Labview To SolidWorks(or autoCAD) Stress Analysis
Can I import real time data that I am measuring on a real system using Labview into a stress simulation on a SolidWorks model of the system? (Basically I have force data in labview from a strain gauge on a simple cantilever beam and I want to apply that changing force to my beam model in Solidworks)...-
- solidworks
- realtime
Stress Analysis: Use outputs from stress analysis for defining input parameters
petedow posted a topic in Autodesk Inventor
Is it possible to take outputs from the stress analysis such as reaction moments around fixed constraint and to define these as a parameter on input to other parts of inventor. e.g. the force in the downwards direction around a bolt hole modelled as a fixed reaction is 200N. Can you then use th...-
- parametric
- inventor
I can change the number from -100 to +100. What this value means?
Inventor 2010 add-inns not showing in ribbon. Stress Analysis tool bar greyed out
kiwicadman posted a topic in Autodesk Inventor
I'm looking to teach Inventor. A local high school has given me an "Educational Institute Version" copy of Pro which I've loaded up to SP4. With no add-ins loaded at startup, the stress analysis tool bar will light up when the add-in is loaded and then grey out again. I have tried the Autodesk fix...- 6 replies
- add-ins
- add-in manager
