Showing results for tags 'status toggle'.
    • status toggle ×
  1. Is it possible to use a command or button when you are drawing something? For example; I've made a toolbar for changing the polar angle into different angles. One for 30 degrees, one for .... degrees, etc. If I am drawing a polyline, and I need to change this angle, I can not use any button...
