Showing results for tags 'spot elevations'.
    • spot elevations ×
  1. I have a couple of viewports where I just want to show spot elevations of my surface and not the contours. Whenever I freeze the contours my spot elevations disappear too. When I select a spot elevation it's layer shows as "C-TOPO-TEXT" and when I right-click and go to "Edit Label Style" the label l...
  2. Problem: We developed a proposed surface and generated contours from a 3D Corridor. The spot elevation labels were added along the corridor in each sheet file. When some of the spot elevations were changed, and some minor profile adjustments were made to the base line, the elevation...
