Showing results for tags 'special characters'.
Problem renaming special characters in Layers
gustavobernardi posted a topic in AutoLISP, Visual LISP & DCL
Hi, Why sometimes this operation returns wrong: (defun c:cvt() (setq oldname "ESP - Esquadrias CIR")(setq newname "ANT - Esquadria Círculo")(runtorenamelayer) ) (defun runtorenamelayer() (if (and(tblsearch "layer" oldname)(not(tblsearch "layer" newname))) (COMMAND... -
Hi folks My target was to do a little routine that creates layouts for the views and sets page setups for these layouts. Name of the page setup is asked from the user before making the layouts and I try to use PromptKeywordOptions so that user can only select existing page setups. And here...
- 1 reply
- special characters
- promptkeywordoptions
how to get to the power of ???
mkv123 posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
here it is if i want to put m (cube) is there is any way to put m^3 in autocad as it is in unit.how to get special characters in autocad....- 13 replies
- meter cube unit
