Showing results for tags 'solidworks api'.
    • solidworks api ×
  1. nagendra vr
    Macros in solidworks (Please Help)
    hello EveryoneI wanted to save my sheet metal parts as flat pattern into Dxf file. So I created a macro for this.I have more than 50 files and wanted to run this macro on every file.I tried using Run custom task under task scheduler but its asking for exe file as program Path.Please help me with thi...
  2. Check out this new Engineering & CAD automation service. AutoEngr.com. Our services include CAD API programming and parametric modeling services for zero up-front costs. We create custom automation to match you needs, then run it whenever you need to complete the task. It's a hassle free l...
  3. Hello, I am fairly new to SolidWorks and even newer to scripting. Our design department recently came to me wondering if there was a way to create a macro that when they selected a part in the feature tree on the left hand side, and pushed the macro hotkey, if the name could be copied to the cli...
