Showing results for tags 'solid object'.
    • solid object ×
  1. hi, I want to convert a complex object into solid, so that I can measure its volume. Please see attachment. regards, Object.dwg
  2. hello everyone, i have a project that needs to get the volume of the certain of the hull of a boat. from 2D i use align command to get the 3D form of the hull. then i to get the shape/surface i use loft command. i am doing it right? but from the moment i tried to get the volume using massprop comman...
