Showing results for tags 'solid modeling'.
    • solid modeling ×
  1. Hey All, I am working on a 3D model of a pool floor for a project that to be supported by walls. I have just started to use surface modelling and I thought I would give it a go using it, when I have gone to convert it to a 3D solid using the sculpt tool I get the error message "Modeli...
  2. how would you create a miter for the shown mouldings? the profile of the moulding is shown on the left. The moulding is a cornice for an interior room, pictured from below (reflected ceiling plan). Thanks in advance for any help. miter help.dwg
  3. I'm modeling a fireplace in AutoCAD 2012 that has 2 solids that won't slice or work with boolean operations. I'm trying to subtract the joints out of the header and legs of the fireplace to create seperate pieces but it won't do it. Slicing the solid at the joints doesn't work either. The 3d...
