Showing results for tags 'solid edges'.
  1. I'm trying to access data from 3D solids. I've been working out some rather involved routines to comb through the ACIS data and piece it back together but there must be an easier way. If a face can be identified and assigned a color through a simple click, then surely there is a way to access this information about the solid without exploding it or digging around in an ACIS file. It feels like the kind of information that could be accessed by descending through subentities associated with the solid but unless I'm missing it, that only leads to the ACIS data. I ultimately want to create arrays of points on the faces of solids and I was working down the path of drawing polylines on the faces to set boundaries for the arrays, but for now I'm reluctant to forge much further down the ACIS route since my gut tells me there is an easier way. What am I missing?
