Showing results for tags 'solid dots'.
    • solid dots ×
  1. Hi, I am using autocad 2008, I am having a problem with dimensions arrow head (Solid dots) when ever i give dimension the arrow head doesnt appear as solid fill, it shows radial lines in that circle, whereas in some files it does appear correctly (see the image). Do i have change any value f...
