Showing results for tags 'slow performance'.
    • slow performance ×
Found 7 results
  1. Hey everyone, While i'm using autocad2017, when i need to move blocks, big or small dimensions, it gets unbelievable slow, impossible to work with. When i need to move blocks i use AutoCAD2015, it doesn't get slow at all. only on 2017's version. Is there any option i should consider?
  2. In AutoCAD 2011, using 3d wireframe Visual Style, by default, clicking in any (non-visible surface of a) 3d solid results in that solid being selected, even if the click is made directly on a line of an object "behind" the 3d solid. AutoCAD 2010 did not do this by default. By default, AC2010, i...
  3. Dear all; Why this happens!!! I had open a file (size 37MB), it is almost purged I just purge 4 nos. of layer, 3 blocks, 1 line type & 9 registered applications deleted. Now save, the file size become 80MB I am using AutoCAD 2013 (Pirated software, which downloaded from some torrent website...
  4. djolegaf
    Civil 3D 2014 very slow
    Hi everyone, this is first time that I am posting on this forum, and I hope that I will get help. I am using Civil 3D 2014, and a couple days ago I changed my ATI HD 4850 with Nvidia GTX 570 2.5GB. And I did not noticed any improvement with new card! My road is about 5 km long, I have about 3000 po...
  5. Hi guys, I work in a company that has 6 CAD drafters. We are all running AutoCAD 2013 on the same machines with same specs and everything. We are running Dell Precision WorkStation T7500 x64 Windows 7 Professional 64 bit with Intel Xeon CPU (E5620 @2.40 GHz, 4 cores) BIOS: Phoenix ROM BIOS...
  6. hey guys, been having some odd performance with my student version of 13. i've completely uninstalled and re downloaded it from autodesk with the sp and update 1, and it still does it. it would be a few things. first off, when i create a new part the ribbon stays grayed out for quite a bit, b...
  7. Firstly thanks for all your help on previous questions. On most occasions, when closing a dwg file with other dwg files still open, a dialog box will open saying ‘non responsive program, autocad must close’. The remaining open files losing any work on them done since I last hit save ( i thought...
